Activity › Forums › Apple Final Cut Pro Legacy › Where is my smoothcam…?
  • Where is my smoothcam…?
    Posted by Tore Jonssen on June 8, 2007 at 6:00 am
    After installing Final Cut Studio 2, I was looking forward to trying out the new “Smoothcam” effect in FCP. Problem is, it doesnt show like the manual says it should, in “Effects->Video Filters->Video->Smoothcam. FCP 6.0 on a brand new MacBook Pro.
    Any ideas?
    Tore Jonssen replied 19 years ago 3 Members · 7 Replies
  • 7 Replies
  • Tore Jonssen
    June 8, 2007 at 6:46 am
    Just found out…there was a corrupt plugin-pack that also caused Motion to crash on my drive. Deleted every associated file, and now my Smoothcam effect is back….
  • Bill Kelly
    June 8, 2007 at 7:43 am
    Ya it’s the FXPack that causes trouble with Motion crashing, smoothcam, and all the associated FXPlugs. The good news is that they released a new update a few days ago that solves all the problems. I downloaded it and everything works great now.
  • Chad Johnson
    September 28, 2007 at 4:43 pm
    Can you give a little more info about this FX pac and the fix for smoothcam?
    I’m in a bind. I have installed shake and lost smoothcam. I don’t know how to use shake yet.
    Chad
  • Chad Johnson
    Chad
  • Tore Jonssen
    September 28, 2007 at 5:46 pm
    It’s been a while since I had this problem now, but as I remember it I got an error message upon opening Motion. The error message was regarding an installed FxPack from Noise Industries. After I cleared all files and folders related to this plugin-pack from my Mac, everything went back to normal. Why don’t you try and uninstall Shake and see what happens?
  • Chad Johnson
    September 28, 2007 at 6:55 pm
    I will.
    Chad
  • Tore Jonssen
    September 29, 2007 at 6:47 am
    Shake has a totally different user interface than what you might have seen before if you’re not familiar with node based software. If I remember correctly, Motion also has the SmoothCam filter built in. Using Motion, the learning curve might not be that steep if you’re in a hurry to stabilize your footage…
    good luck!
    Tore
