Activity Forums Adobe After Effects Where is my head?
  • Where is my head?
    Posted by jess Mah on February 28, 2025 at 4:00 am
    I have this 3d object in the scene and a 3d plane as a background – the head can be seen in other views but strangely disappeared in the top view – and the background plane is no where to be found – even when the object is a current selectin it is not showing in the other views. Is this a bug?
    https://youtu.be/uWulMjPfjnw
    jess Mah replied 1 year, 5 months ago 2 Members · 2 Replies
  • Graham Quince
    March 1, 2025 at 7:06 am
    If you toggle the Mask and Shape Path visibility switch in the comp window, it should highlight where the 2D plane is. It’s a little odd, but my guess is they are both just off the stage.
  • jess Mah
    March 25, 2025 at 1:08 am
    Thank you! 🙂
