Activity › Forums › Adobe After Effects › Where is Keylight in AE CS3
  • John Dickinson
    July 28, 2007 at 9:10 pm
    Hmmm, sounds strange. In AE CS3 Keylight (and the Cycore effects) are installed as part of the main installation. Should be there.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Tim Kurkoski
    July 30, 2007 at 6:14 pm
    If you’re using the trial version, Keylight won’t be there. Also, make sure that you selected to install all components, as the third-party content can be deselected.
    But otherwise, as John said, Keylight and the other third-party stuff installs at the same time as AE.
