Activity › Forums › Apple Final Cut Pro Legacy › Where is Graffiti (FCP5)?
Posted by Morten on June 10, 2005 at 8:30 amI cannot se the Graffiti titler after updating to FCP5 – it iss not on any of the CDs either?
– No Parking Production –
FCP 4.5, Dual G5, X-Raid
Mitch Ives replied 21 years, 3 months ago 5 Members · 4 Replies -
Chi-ho Lee
June 10, 2005 at 12:41 pmI believe it is just listed as Boris now.
-CHL
Chi-Ho Lee
Film & Video Editor
Apple Certified Final Cut Pro Trainer -
Phillip Van west
June 10, 2005 at 2:22 pmWhen I installed FCP5, Title 3D and Title Crawl weren’t in the generator pulldown or in the Effects tab of the Browser. They WERE, however, in the plugins folder. I simply put the 4 Boris plugins (yes there are 2 new ones) in their own subfolder (I just called it “Boris”) within the plugins folder and they then appeared in the usual places in FCP. Can’t explain why this works but it does. Hope that helps.
pvw
Terra Nova Productions LLC
G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.4.1 / FCP 5.0 / QT 7.0.1
Francois
June 10, 2005 at 3:28 pmI guess your mean Boris Calligraphy ? not Graffiti
it’s Boris Calligraphy 2 now
in this case pvanwest workround works (can do do bad anyway)
also, if you launch Fcp with just those two plugs they will be there anyway,
reinstall the other one by one if you wanna be sure of compability (one failing can bring the others down)Fcp rules
Mitch Ives
June 10, 2005 at 3:40 pm[Morten Ranmar] ” I cannot se the Graffiti titler after updating to FCP5 – it iss not on any of the CDs either?”
Graffitti is Boris standalone CG… it was never included with FCP. What you are refering to was the Caligraphy plugins. They now appear under a “Boris” menu in the Generator popup, and are automatically installed when installing FCP 5 (at least they were for us)…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com
http://www.insightproductions.com
