Activity Forums Apple Final Cut Pro Legacy where is DVCPRO NTSC?
  • where is DVCPRO NTSC?
    Posted by Vanessa Shaw on November 17, 2010 at 9:02 pm
    I’m working on a job where they gave me 3 DVC PRO50 NTSC tapes. I have a rented deck to work with, but I can’t seem to set up my Log and Capture so that I can see the footage.
    What should my capture settings be? I don’t see DVCPRO NTSC, just PAL.
    Thanks!!
    Vanessa
    Vanessa Shaw replied 15 years, 9 months ago 5 Members · 12 Replies
  • 12 Replies
  • Rafael Amador
    November 17, 2010 at 9:06 pm
    Instead of DVCPro50 you may be getting “DV50” in your codecs list.
    About DVCPro(25), in NTSC-land, is the same than plain DV.
    rafael
    http://www.nagavideo.com
  • Vanessa Shaw
    November 17, 2010 at 9:18 pm
    Thanks for the tip.
    I changed the setting, but I still can’t see anything in my Capture Scratch window…
  • Paul Jay
    November 17, 2010 at 9:29 pm
    Use the EASY SETUP
    Choose format: NTSC
    Choose framerate 29.97
    Click on formats.
    Which one do you see? Is it there? DV50 should be there.
    Which FCP version do you have?
  • Vanessa Shaw
    November 17, 2010 at 9:39 pm
    At this point I think it is an issue with the deck. My FCP (v.6) is able to control the deck, I’m just not seeing anything in the Capture Scratch window.
  • Rafael Amador
    November 17, 2010 at 10:05 pm
    Vanessa,
    In the Capture Window> Capture Settings Tab> Capture?Imput, you should get all the Capture Presests.
    If the DV50/DVCPro50 isn’t there, duplicate the DV-NTSC Capture Preset and (Edit) change the codec by DV50.
    rafael
  • Paul Jay
    November 17, 2010 at 10:26 pm
    Capture scratch?
    You mean log and capture window.
    Is the capture window black or does it say ‘preview disabled’?
    Your deck is connected through firewire? Any other firewire devices connected?
  • Vanessa Shaw
    November 17, 2010 at 10:50 pm
    Yes, I mean Log and Capture.
    no other firewire devices connected..
  • Vanessa Shaw
    November 17, 2010 at 10:51 pm
    Yes, I mean Log and Capture. It’s black, not preview disabled. and the timecode is running.
  • Rafael Amador
    November 17, 2010 at 11:10 pm
    Have a look to the FW setting and connexion.
    rafael
  • Tom Matthies
    November 17, 2010 at 11:26 pm
    DV50 NTSC 48K
    -should be the preset you need.
    Tom
    Faster! Better! Cheaper!
    Pick any two.
