Activity Forums Boris FX Where is Boris installed within AE 5.5
  • Where is Boris installed within AE 5.5
    Posted by Danny Mcconnell on February 19, 2012 at 2:45 pm
    I am trying free trail of the Boris Continuum Complete AE 7 but can’t seem to find it with After Effects 5.5?
    I found the file C:Program Files (x86)Boris FX, Inc when i copy it to the Adobe Plugin folder it does not show up under After Effects Preset? are am missing something here?
    Regards
    Danny
    Jeremy Ellis replied 14 years, 6 months ago 2 Members · 5 Replies
  • Jeremy Ellis
    February 19, 2012 at 5:41 pm
    Hello Danny,
    The plugins should install to the follow directory:
    C:Program Files>Adobe>Common>Plug-ins>CS5.5>MediaCore
    Thank You
    Jeremy
    Boris Support
  • Danny Mcconnell
    February 19, 2012 at 6:42 pm
    Can’t still see them. Are they allowed to stay in the folder. I am on Windows 7 64bit. Is there a guide for it?
  • Jeremy Ellis
    February 21, 2012 at 2:41 pm
    What you would want to do is run the installer and select Custom Install as opposed to Complete Install. This will allow you to make sure the AE 5.5 is selected and it will show you the path to which it is installing. If the path is incorrect you would want to change it there to C:Program Files>Adobe>Common>Plug-ins>CS5.5>MediaCore
    Thank You
    Jeremy
    Boris Support
  • Danny Mcconnell
    February 21, 2012 at 3:50 pm
    I am using BCC7 take it not compitable with AE 5.5?
  • Jeremy Ellis
    February 21, 2012 at 8:33 pm
    It is compatible, however if you are not using the latest installer it may not show an option for CS5.5 in the custom installation.
    Thank You
    Jeremy
    Boris Support
