Activity Forums Avid Media Composer Where is Avid Pan & Zoom (Avid XDV 3.5.4)
  • Where is Avid Pan & Zoom (Avid XDV 3.5.4)
    Posted by Wizeson on May 26, 2005 at 9:04 pm
    I just got assigned a project for which I will need to use the Pan & Zoom Plugin. I received an “unlocking” code for it when I registered my system but alas the Pan & Zoom is nowhere to be found – it isn’t in my Avid Effect Pallete, nor is there an installer for it on my disks. Is it possible I was accidentally not given the Plugin with my system? If so, is there anywhere I can download it online?
    Jokuh replied 21 years, 3 months ago 3 Members · 2 Replies
  • Jeff Mullen
    May 27, 2005 at 5:28 pm
    I may be wrong, but is the Pan & Zoom effect only for Pro, not DV?
    Cheers!
    -jeff mullen
  • Jokuh
    June 2, 2005 at 7:33 am
    you should have been offered a download option for the plugin itself as well when registering.
    if not: contact customer support
    hth
    jokuh
