Activity Forums Apple Final Cut Pro Legacy Where is AVI export in Compressor?
  • Where is AVI export in Compressor?
    Posted by Michael Buday on March 13, 2006 at 5:55 pm
    I’ve got to output a number of of sequences to uncompressed AVI for a client. I’ve exported all of them as Quicktime reference movies so I can use Compressor to batch export them. However, I cannot find “AVI” export anywhere in Compressor, even though Quicktime Pro has this export option.
    Am I missing something? I was under that impression that Compressor “uinherited” all the available export capabilities of Quicktime. Am I wrong?
    Many thanks!
    Michael Buday
    David Bogie replied 20 years, 6 months ago 3 Members · 3 Replies
  • Debe
    March 13, 2006 at 6:12 pm
    It’s a two-step process to get there.
    Under Settings>New Default Settings, choose QuickTime Export Components.
    Then in the Inspector, the file format drop down should change to QuickTime Export Components. If it doesn’t change it there as well.
    Then the Encoder Type drop down in the Inspector will have AVI as an option, with the AVI Options button active.
    debe
  • Michael Buday
    March 13, 2006 at 6:21 pm
    Thank you Debe! I’ll give that a try.
    Many thanks again.
    Michael Buday
  • David Bogie
    March 14, 2006 at 3:13 pm
    Before you invest too much time messing with this, try to get the precise specifications from your client for the file they are expecting from you. AVI is ancient and permeates the PC world only because the operators of the computers are too terrified to update to modern players. There were hundreds of codecs for AVI and only a scant handful were ever available for Macintosh. None of them are current AFAIK.
    You may need to move this project to PC. Unlikely, but it depends on their perceived need for what they think AVI will accomplish.
    bogiesan
