Activity › Forums › Apple Final Cut Pro Legacy › Where is audio level adjustment?
  • Where is audio level adjustment?
    Posted by Dave Felder on August 30, 2005 at 3:41 pm
    Trying to capture from a BetacamSP VTR, through a Decklink card to FCP 4.5.
    When I slide the “GAIN” adjustment in Capture settings, it has no effect. Additionally, the other clip settings are greyed out. For my settings, I am using Decklinke NTSC 8 bit.
    I understand that DV is not adjustable. Is Decklink turning the Analog Betacam signal into a DV signal and that’s why I can’t capture it?
    Ryan Video Productions Inc. Rockaway, NJ
    Bret Williams replied 21 years, 1 month ago 5 Members · 6 Replies
  • Rick Dolishny
    August 30, 2005 at 3:58 pm
    I think you’re going to have to go through a mixer en route to the FCP. I’ve never touched those settings I don’t think they’re always active.
    – R
  • Bouncing Account needs new email address
    August 30, 2005 at 4:04 pm
    Yes, most who want to adjust the analog gain during CAPTURE (not a good idea, really) usually route the audio thru a mixer.
    The main problem with making adjustments during capture is not being able to accurately repeat them during a “batch capture” at a later time.
  • Dave Felder
    August 30, 2005 at 4:10 pm
    Why do you say it’s not a good idea to adjust during capture? If the tape is recorded at -18 DB, you think it’s better to capture like that, then adjust in the timeline? Is there more dynamic range available then?
  • Rick Dolishny
    August 30, 2005 at 5:11 pm
    No, it’s just like Matte said, audio should be digitized at “preset” levels so you can recapture it later with a degree of confidence and accuracy. Technically you could set Gain every time to load a new tape but more often than not the tape may not have bars, or frankly the bars may be irrelevant when it comes to audio.
    At least in my experience.
    For audio it’s best to leave your capture gain at present unless its’ a hopeless tape, but even then I adjust the Playback levels directly on the deck before touching the capture levels.
    – R
  • Dave Jenkins
    What your asking for is standard in most other systems. We used Media 100 and adjusted the levels in the capture process so our external mixer levels can stay at one level. This is very helpful for recapture at a later date. I would email sales at AJA and request this feature.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Bret Williams
    September 3, 2005 at 3:58 am
    Dave, don’t worry. FCP supports the feature. Just not your card, that’s why they’re greyed out.
    And FCP records the settings for each individual clip, so this WOULD be the correct way to do it if Decklink permitted. Unless a tape is royally screwed, the incorrect way would be to adjust gain with a mixer manually for each clip. That is a sure fire way to make it impossible to batch capture.
    That all being said. I generally capture everything normalized. The way it was shot. Then do all mixing within FCP. I use dv or IO. Neither supports changing the gain upon capture.
    I too used Avid and Media 100. Those are turnkey systems. One system fits all. With an open system you get rapid development and more options. Not everyone takes advantage. I think Cinewave took advantage of the audio gain. Cinvewave was most similar to the older systems like media 100 and avid where the effects were performed by the card.
    Even back then I captured everything normalized.
