Activity Forums Apple Final Cut Pro Legacy where does Compressor put renders pre-FTP?
  • where does Compressor put renders pre-FTP?
    Posted by Joe Mcneilly on June 10, 2010 at 10:05 pm
    I tried to use Compressor’s new FTP function, but the problem is thus. The FTP timed out, which caused the job to fail. I can’t find the rendered .mov anywhere, so I can’t just manually FTP it. Looks like I have to go back and render the entire thing again. Does anyone know where the render file goes? Can I rescue it from a cache somewhere so I don’t have to encode the entire project again?
    Chad Von nau replied 14 years, 10 months ago 4 Members · 4 Replies
  • Arnie Schlissel
    June 11, 2010 at 2:03 am
    Compressor puts the file wherever you tell it to go. Where did you specify that the file is saved? That’s where it is.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Joe Mcneilly
    June 11, 2010 at 1:45 pm
    When you specify “FTP” as the destination, there’s no obvious path to the local file. So if the FTP fails, the output file seems to vanish. But it must be in a local cache somewhere, right?
  • Jeremy Garchow
    June 11, 2010 at 2:25 pm
    There’s a cache, but it’s usually not a whole QT movie.
    From Finder > Go to Folder then type
    /var/spool/qmaster. I bet there’s files in there but nothing readable, but maybe?
  • Chad Von nau
    November 7, 2011 at 7:56 am
    The files are saved in /var/tmp
