Activity › Forums › Apple Final Cut Pro Legacy › where do you guys digitize footage to?
Posted by Jason Brown on July 31, 2009 at 5:44 pmHey Guys,
Quick poll. Does anyone here digitize/import their media into a project folder rather than the *capture scratch* folder?
It seems from a media management that it may be easier to put all media into a project folder rather than all of it in one main folder.
Anyone do anything like this? Why or why not?
-Jason
John Fishbackreplied 17 years, 1 month ago 7 Members · 6 Replies
Chris Poisson
July 31, 2009 at 5:57 pmUnder System Settings, you select the folder to which your capture scratch and render files go, among other things. Most people here keep their projects on their boot drives and all their media and render files on selected folders on the media drives. No one that I know keeps all this stuff in one folder.
Have a wonderful day.
Shane Ross
July 31, 2009 at 6:29 pmFCP does separate your footage by Project. In the CAPTURE SCRATCH folder, FCP creates subfolders, one for each project. So all the media won’t get mixed up.
But I tend to use a CAPTURE project, capture my footage, then move it to a folder that I make for each project, that contains the Captures, Music, SFX, STILLS…everything for that project.
Shane
Read my blog, Little Frog in High Def -
Matt Callac
July 31, 2009 at 6:49 pmIt really depends on your workflow. I don’t move the media. I keep it in the capture scratch in the folder with the project name. then on the media drive I have an images folder, music folder, AE renders folder etc etc.. inside those folders are folders with the project names containing that specific media. That way if I need to gather all of one projects things I can just search for the project name in spotlight and move the media wehre i need it.
-mattyc
John Knapich
July 31, 2009 at 6:59 pmLike most people we leave our media in the FCP Capture and Render folders on our media Raid.
In addition, we make a project folder on the media raid that contains all our other external files: gfx, music, docs, encodes, FCP back ups, etc.
When we archive a project (just the media from the final timeline) to Blu-ray, we include the project folder. -
Mark Raudonis
July 31, 2009 at 9:10 pmI’m with Shane on this, but we take it even further.
Because we’re dealing with multiple projects, many editors and shared storage, we use “capture projects”, but then move the media BEFORE anyone starts editing to a logical folder structure. We capture local on many different systems, then move global (SAN) into a pre determined folder structure.
Letting FCP do media management will work up to a certain point, but then things just get too complicated to keep everything straight. There’s no “magic” to the capture scratch folder. It’s just FCP’s attempt to help you keep things organized. At a certain point, you’re better off creating your own project organization… especially in a shared storage environment.
Mark
John Fishback
August 1, 2009 at 9:17 pmWe let FCP create the project sub-folders on the capture drive. But, we put folders for music, gfx, etc. inside each project sub- folder. It makes it easy to archive projects as all the media is in one place (except for the renders which we typically don’t archive).
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
