Activity Forums Apple Final Cut Pro Legacy Where do I put new transition files?
  • Where do I put new transition files?
    Posted by Joey Williams on August 12, 2009 at 3:42 am
    I just downloaded the alpha transitions from Apple.com, but the download didn’t come with the standard “read me first – download directions” file that usually comes with that stuff. It is a standard FCP7 install – where do these durn files go?
    Thanks.
    JW
    TOAD ARRAY
    https://toadarray.com
    Chris Gen replied 16 years, 10 months ago 3 Members · 3 Replies
  • Steve Eisen
    August 12, 2009 at 5:26 am
    You are not installing an application. Place the Alpha Transitions folder somewhere on your hard drive. When you want to use them, place the Alpha Transition (Effects/Video Transitions/Wipe/Alpha Transition) between two clips. Double click the transition. Drop the files into the wells.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Joey Williams
    August 12, 2009 at 7:20 pm
    I know its not like installing an app – I just thought that they had to go into a specific “transitions” folder.
    So I just put them somewhere accessible, and ‘file>import” them when I need them?
    Thanks for the info.
    JW
    TOAD ARRAY
  • Chris Gen
    November 7, 2009 at 7:34 am
    I have a questions about alpha transitions and favoriteing it.
    I wanted to favorite the lens flare transition from the new alpha transitions. But if I don’t load the folder called Alpha Transition that I downloaded from apple, each time I dropped the favorite transition to the time line, it says media off line.
    Is there a way I don’t have to repeat adding the folder in the browser for each project every time? It seems a bit tiresome…
    Thank you very much,
    Sincerely,
    Chris
