Activity Forums Lighting Design Where do I find Mylar?
  • Where do I find Mylar?
    Posted by David Distinti on May 16, 2005 at 2:20 pm
    I need to block all natural light from coming in through our location’s windows.
    I understand sheets of mylar will do the trick. Where can I find it and what type of
    mylar should I request.
    Also,
    If mylar is expensive, is there a cheeper alternative?
    Dave
    Dan Rahmel replied 21 years, 3 months ago 4 Members · 4 Replies
  • Leo Ticheli
    May 16, 2005 at 2:30 pm
    A “cheeper” alternative would be a flock of baby chickens.
    A cheaper alternative would be standard construction material black plastic.
    Best regards,
    Leo
    Director/Cinematographer
    Southeast USA
  • David Distinti
    May 16, 2005 at 2:44 pm
    Thanks for the “cheep” tip. 🙂
    – Dave
  • Bob Cole
    May 16, 2005 at 3:47 pm
    This forum is going to the birds.
  • Dan Rahmel
    June 10, 2005 at 9:00 pm
    You’re trying to block all the light? It seems like you want sheets of Duvetyne (a solid non-reflected black cloth you can get at Film Tools). I guess I don’t understand exactly what you’re looking for.
    For Mylar, take a look at TAP Plastics (https://www.tapplastics.com). I’ve ordered from them a couple of times and they were good. They have mylar rolls (mirrored and clear) you can order.
    Mylar is usually fairly expensive and traditionally used for its mirror-like surface. If you don
