Activity Forums Adobe Premiere Pro Where did my Filmimpact plugins go?
  • Where did my Filmimpact plugins go?
    Posted by Joe Chow on August 13, 2013 at 10:35 pm
    I downloaded Premiere Pro CC 2 weeks ago and played with it a bit before going back to work on an ongoing CS6 project. When I was in CC, I noticed that my plugins (some transition effects) bought from FilmImpact.net were no longer available. I went to their site and it said I had to reinstall them thru Extensions Manager CC. So I downloaded that and seemingly installed them successfully. I even played with them a bit in my PP CC test project. So it’s 2 weeks later, I open up PP CC and it tells me that the effects are missing. I open Extension Manager CC and I see that the plugins are “enabled”, but they’re not in Premiere. Any idea what’s going on and whether I can get them back?
    Thanks.
    Joe Chow replied 13 years ago 4 Members · 6 Replies
  • Tim Langston
    August 14, 2013 at 1:30 am
    Same thing happened to me, I ended up just reloading and they popped back in.
    Tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
  • Joe Chow
    August 14, 2013 at 1:49 am
    I just did the same thing. Originally I didn’t do so because I couldn’t find the ZXP for the plugins. Still, it’s annoying that the Extension Manager showed that the plugins were “enabled” when they weren’t.
  • Ann Bens
    August 14, 2013 at 10:42 am
    You need to contact FilmImpact.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • David Gaudio
    August 14, 2013 at 4:39 pm
    This has happened to me several times; usually whenever the program is upgraded. Opening Extension Manager and reinstalling the keys was the trick. Just have your keys in a convenient folder. It’s a pain, but just takes a minute to fix, and it only seems to happen during an upgrade.
  • Joe Chow
    August 14, 2013 at 4:44 pm
    Unfortunately it’s not a FilmImpact problem, but an Adobe problem. And I posted to their message boards. Didn’t get as many responses as I did here.
  • Joe Chow
    August 14, 2013 at 4:46 pm
    Yes. I have done so now. And you’re right. I did lose the plugins when I upgraded. The dumb thing is that Extension Manager still says they’re “enabled” when they’re not. Annoying. Another one of those Adobe “2 steps forward, 1 step back” things that they do. Thanks for your response.
