Activity Forums Adobe Premiere Pro Where did I go wrong?
  • Where did I go wrong?
    Posted by Bruce Scott on May 4, 2012 at 12:43 am
    We had a computer built for Premier Pro, but we are disappointed. We are new to Pro 5.5, so maybe we are expecting too much. Almost any video transition must be rendered. Everything seems slow compared to our old Velocity HD system. How would you rate the following system for running Premier Pro and After Effects?
    16GB RAM
    3.4 GHz Intel i7 Quadcore CPU w/Hyperthreading w/SuperMicro C7P67 motherboard
    (1) 1TB 6Gbs SATA 7200RPM Seagate HD, Partitioned for C, Swap and Projects
    (2) 1Tb 6Gbs SATA 7200RPM Seagate HDs, Striped as Video Drive
    G-Force 570 1.25GB, dual-monitor VGA w/DVI
    Windows-7 Professional; 64bit OS
    BlackMagic Intensity Pro Capture Card
    Bruce
    David Mcgavran replied 14 years, 4 months ago 3 Members · 2 Replies
  • Gus Evangelista
    May 4, 2012 at 1:28 am
    Rendering Transitions? What kind of footage are you using, and are you using the correct sequence preset (which will become obsolete once CS6 comes out)?
  • David Mcgavran
    May 4, 2012 at 2:21 am
    Is Mercury GPU turned on? Look in Project settings
    Cheers
    Dave
    David McGavran, Adobe Systems Incorporated
    Engineering Manager Adobe Premiere Pro
