Activity Forums Blackmagic Design Where can I find the 10-bit codec only?
  • Where can I find the 10-bit codec only?
    Posted by Thomas Horne on October 11, 2009 at 5:05 pm
    I was told that the hardware drivers include the codec, but I don’t have any Blackmagic hardware, and cannot download the drivers without a serial number.
    I have a lot of final renders in the BM codec. I often use BM codecs when preparing final renders for tape layoff at an external facility. The site used to have a codec-only download for just this purpose. Now I can’t seem to find it anywhere.
    Anyone know where I can get it?
    Thanks…
    Geo Brick replied 15 years, 8 months ago 3 Members · 3 Replies
  • Kristian Lam
    October 11, 2009 at 11:17 pm
    Hi Thomas,
    You can download without registering. Just click on the Download Now button instead of the Register & Download button.
    That said, the codecs we include in our drivers are the Apple Uncompressed 10-bit codecs which are compatible with the Blackmagic 10-bit codecs you’re used to.
    regards
    Kristian Lam
    Blackmagic Design
  • Geo Brick
    December 18, 2010 at 7:14 pm
    Sorry to drag up an old thread, but..
    When you download a black magic driver and run the msi file (windows), it says it can’t be installed without the hardware installed.
    I don’t have any black magic hardware but I do have several black magic encoded files from Debenham media (16mm film transfers).
    What would I need to download at https://www.blackmagic-design.com/support/software/ that would allow the codec to install.
    While I’m at it, I’ve read there are Premiere Pro sequence presets for black magic (which I don’t have). If I want to preserve an edited project in the lossless format, what sequence settings and what media encoder options do I select in Premiere Pro CS5? Is there a place to get the sequence presets or can you point me to a place that describes the settings so I can create my own custom settings?
  • Geo Brick
    January 2, 2011 at 7:01 pm
    I’ve answered my own question. I found blackmagic codec options in AME under the Microsoft AVI format in the Video CODEC pulldown list. (I’m not sure if this was there before I installed the PP functional content.)
    I still see no sequence presets for blackmagic encoded video but I can just drag the clip to the “new item” button and a sequence based on the clip properties will be created.
