Activity Forums Apple Final Cut Pro Legacy Where are the other Prores version in log and transfer window
  • Where are the other Prores version in log and transfer window
    Posted by Jakob Mortensen on February 27, 2011 at 6:36 pm
    Hi
    I am working with AVCHD files in FCP 7.0.3. I use log and transfer to ingest, but since my material is from a consumer cam Panasonic G2, the Prores 422 seems to be overkill. I want to use the Prores 422 LT version BUT i can not choose that in the settings window (the gear symbol in the middle of the log and transfer window).
    So where do I set that option ?
    Best wishes
    Jakob
    Jerry Hofmann replied 15 years, 6 months ago 4 Members · 3 Replies
  • Phil Balsdon
    February 27, 2011 at 8:59 pm
    You need to click the first ProRes option you see and it will show you all the options, then select one of those.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://www.steadi-onfilms.com.au/
  • Steve Eisen
    February 27, 2011 at 9:06 pm
    Log and Transfer Preferences.
    Under AVCHD Plugin (Source Format) you should be able to select you ProRes option (Target Format).
    One thing I did notice in my L & T window is the option for MPEG2 Consumer Cameras, MPEG2SD. It only allows for ProRes422
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jerry Hofmann
    February 27, 2011 at 9:09 pm
    Click on the little arrows just to the right of the ProRes 422 setting… LT is there in a pop up.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
