Activity Forums AJA Video Systems Where are the 8-bit and 10-bit quicktime codecs located?
  • Where are the 8-bit and 10-bit quicktime codecs located?
    Posted by Mike on August 1, 2005 at 11:25 pm
    One of our G5s had a currupt system file and would not boot, so I needed to do an “arhive and install” to bring it back up and running. Although most of my user settings appear intact, I no longer have the two uncompressed codecs as an available quicktime codec. Is it possible to pull these codecs over from one of my other Kona 2 machines? If so, where in OSX are these files located? I tried doing a search but could not find them. Any help is greatly appreciated.
    Mike
    Dual 2.5, 2.5 GB RAM, 10.3.9, 3.5 TB XRAID
    Mike replied 21 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Garchow
    August 2, 2005 at 5:16 am
    HardDrive->library->Quicktime
    You’ll find them in there under FCPUncompressed or something like that.
    I’m not in front of my machine, this is an estimated guess. I take no responsibility if this is wrong 🙂
    I’ll check when I get in the office tomorrow sometime.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Mike
    August 2, 2005 at 2:25 pm
    Thanks Jeremy! That was it.
