Activity › Forums › Apple Final Cut Pro Legacy › Where are Subclips stored?
Posted by David Roth weiss on August 17, 2007 at 3:57 pmCan someone please tell me how FCP names the files that it creates when making subclips and where the heck it stores them? That would be a big help to me just now.
TIA,
DavidDavid Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY
David Roth weiss replied 19 years, 1 month ago 5 Members · 11 Replies -
Mark Maness
August 17, 2007 at 4:04 pmIt doesn’t.
Sub-clips are just that… sub-clips of master clips. FCP can only point to master clips when referring to Quicktime files and sub-clips point to master clips. That’s it.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Shane Ross
August 17, 2007 at 4:13 pmAs Wayne said…there is no new media created. Just a clip that points to a section of the larger media file. FCP stores them in the Browser.
Shane
Littlefrog Post
http://www.lfhd.net -
David Roth weiss
August 17, 2007 at 4:15 pmWayne,
That’s what I thought, but… For some reason an XML file that I created can link all subclips to files on my system, but it can’t seem to link them to the same files on the client’s system. Any ideas why not? This is necessary because the client has an earlier version of FCP.
BTW, the XML file seems to read in perfectly, but all the clips are showing as offline.
TIA,
Director/Editor
Shane Ross
August 17, 2007 at 4:35 pmOooo…another reason to hate subclipping in FCP.
Darn it…why can’t they get this fixed? Is it really that difficult?
Shane
Littlefrog Post
David Roth weiss
August 17, 2007 at 4:43 pmSo Shane, is this something that positively, definitely won’t work no mater what I do? The client has FCP ver 4.5 and it reads the XML and creates a timeline, but so far that’s all. The metadata seems to have no idea what its supposed to link to.
I guess I can try an EDL next??? Its a very simple timeline with simple straight cuts…
David
David Roth Weiss
Director/Editor
Shane Ross
August 17, 2007 at 4:48 pmI don’t know if it won’t work no matter what you do. Someone might have experience with this and offer a suggestion. I haven’t done this (well, I have done an XML, but I never subclip in FCP) so I don’t know what to day.
Sorry mate.
Shane
Littlefrog Post
Tom Wolsky
August 17, 2007 at 5:03 pmWhat version of XML did you export?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
David Roth weiss
August 17, 2007 at 7:49 pmHi Tom,
I exported as XML version 1 primarily because Jeremy G. suggested it. It seemed to work, but alas did not. I finally gave up because I had to relink each clip manually. I had 197 clips…
Director/Editor
Andrew Kimery
August 18, 2007 at 5:02 amWow. That is horrible. I’ve only subcliped a couple of times on smaller projects, but I’m so glad I saw this before I made the mistake of doing any subclips on this doc I’m working on. I knew subclipping in FCP wasn’t as reliable as subclipping in Avid, but this is just ridiculous. In an online/offline workflow subclipping is more of a deathtrap than a feature…
-A
Tom Wolsky
August 18, 2007 at 6:21 amThere may be other issues involved in this besides the material being subclipped. I ran some pretty extensive tests on multiple machines and couldn’t make it do what happened to David. I did use XML v1, but I was not using different versions of the application.
All the best,
Tom
