Activity Forums VEGAS Pro Where are recently used projects stored?
  • Where are recently used projects stored?
    Posted by Paul Gregory on June 2, 2014 at 1:12 am
    Where are recently used projects stored? The reason that I ask is that you are allowed a max of nine. I recently deleted from my PC some that were no longer needed. But what I see that they still appear on this list & there failure to be removed appears to prevent other older ones to appear.
    Thanks in advance
    Aleksey Tarasov replied 12 years, 3 months ago 3 Members · 2 Replies
  • Norman Black
    June 2, 2014 at 2:08 am
    The list is fixed in size and removing something will not cause something older to re-appear. The list is populated as you open projects. If you select a project which has been deleted/moved then, you get an error opening and it will simply be removed from the list and the list will contain one item less than before.
  • Aleksey Tarasov
    June 2, 2014 at 2:18 pm
    Vegasaur Project History has no limits 😉
