Activity › Forums › DaVinci Resolve › Where are my scops?! Resolve 9
Posted by Trevor Adams on August 14, 2012 at 10:37 pmOkay got another one for you. Don’t now why but after installing Resolve 9 I cant see my scopes. Anyone know why? Cant do much without them.
Dwaine Maggart replied 13 years, 11 months ago 3 Members · 6 Replies -
Dwaine Maggart
August 14, 2012 at 11:43 pmOpen the Projects window, right click in it, and select Reset UI Layout.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Trevor Adams
August 14, 2012 at 11:53 pmHmmm yes I tried that but still nothing. Can they be hidden somehow?
Dwaine Maggart
August 14, 2012 at 11:58 pmYou also need to right click in the viewer on the Color page and select the Show Scopes menu. If you have done the Reset UI Layout in the Projects page, then when you select the Show Scopes menu, the scopes should appear in the center of your main GUI display.
Dwaine Maggart
Tom Parish
October 23, 2012 at 6:33 pmFor some strange reason my scopes are ‘stuck’.
I have done what you said here – Open project window and click on Reset Display. In fact I I did that a month or so ago and it worked.
Now they are really stuck. This occurs because I occasionally move my third display that I use for Scopes (for another temporary use in between projects). When I take that scope display away from my iMac (running Lion lastest version) the Resolve scopes move over onto the main display and they get stuck. In fact now they are too high and I cannot move them.
I have a screengrab showing the scopes (too high) and there is no selection when I click right on the project in the project display to reset the display. I tried upgrading to the 9.02 just now and it’s still there.
Any thoughts?
thank you
TomDaVinci Resolve Color Grading Freelancer
Audio Mixing and Finishing
Tom@tomparish.com -
Dwaine Maggart
October 24, 2012 at 5:46 amHi Tom,
In the Project Manager window, hold down the Shift key, then right click in an empty area, and now you will see the Reset UI menu item. Select that, and your scopes should go back to the center of the primary GUI display.
Dwaine Maggart
