Activity Forums Blackmagic Design When will MediaExpress 2 be fixed?
  • When will MediaExpress 2 be fixed?
    Posted by Andreas Wideroe on January 25, 2010 at 8:27 am
    Hey!
    This has been requested many times already, but the Blackmagic reps seems to skip these questions…
    Please, when will you have a MediaExpress update that’s not stuck to 1920×1200 screen resolution?
    A standard fully resizable screen would be perfect.
    Also, you should add the capture formats (codecs) that you support with Premiere into you application aswell as MFX wrappers (if that’s not already there).
    Thanks! Hope to get a clear answer this time about when it will be released.
    Andreas
    Norsk Smalfilm AS
    https://www.smalfilm.no
    Filmshooting | Com
    https://www.filmshooting.com
    Andreas Wideroe replied 16 years, 7 months ago 1 Member · 1 Reply
