Activity Forums Adobe Premiere Pro When using ‘restore unrendered’ effects previously applied to original clip are gone
  • When using ‘restore unrendered’ effects previously applied to original clip are gone
    Posted by Nick Thompson on May 12, 2020 at 3:30 pm
    Hi all,
    I sometimes use ‘render and replace’ on audio tracks with effects on them to speed up playback. The problem is, when I do ‘restore unrendered,’ the effects I applied on the original clip (before using render and replace) are gone. This is troublesome because sometimes I need to restore unrendered to change the parameter of an effect. Does anyone know if there’s a setting somewhere that makes it so Premiere reverts the files back to their state before I rendered them (with adjustable filters, volume, etc re-applied)?
    I’m on Windows 10 on Premiere CC 14.
    Thank you for your help!
    Nick Thompson replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
