Activity Forums Apple Final Cut Pro Legacy When to use 23.98PD
  • When to use 23.98PD
    Posted by Jack Johnson on March 15, 2011 at 9:49 pm
    I’m capturing some HDCAM 23.98 footage and I came across a menu setting on the Sony J-H3. I understand that the PD in 23.98 stands for pull down, but I don’t understand when that setting needs to be implemented and what exactly it does.
    Any information would be greatly appreciated.
    Jack
    Doug Beal replied 15 years, 6 months ago 3 Members · 4 Replies
  • Chad Brewer
    March 15, 2011 at 11:41 pm
    The Sony J-H3 VTR has the 23.98PD setting to add pull-down so you can output a 29.97 signal from a 23.98PsF recorded tape.
    Chad Brewer
    Senior Broadcast Videotape Operator
    TeleVersions, LLC
  • Jack Johnson
    March 15, 2011 at 11:55 pm
    So the J-H3 is actually converting the footage from 23.98 to 29.97 in the 23.98PD setting?
  • Chad Brewer
    March 16, 2011 at 12:38 am
    Yes.
    Chad Brewer
    TeleVersions, LLC
  • Doug Beal
    March 16, 2011 at 4:19 pm
    and depending how you have TC settings could be generating Drop frame code from NDF source which can be a very bad thing in offline / online scenarios
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
