Activity › Forums › Apple Final Cut Pro Legacy › When to use 10-bit rendering
  • When to use 10-bit rendering
    Posted by David Eells on July 3, 2008 at 8:58 pm
    I’ve got a one hour film with XDCAM1080i50, HDV1080, HDV 720p25 and DV Pal in a ProRes422HQ timeline. I’ve been doing some testing with 10 bit versus 8 bit rendering in the video processing tab of the sequence settings.
    If I use 8-bit, I get a lot more real time playback, my renders are much faster than 10-bit, but exporting reference movies takes much longer, and they are huge.
    If I use 10-bit, timeline rendering takes longer and there is much more of it. On the other exporting a reference movie is quite fast (because I’ve rendered in the timeline), and the reference mov is comparatively quite small.
    My thought is to cut using 8-bit, and switch to 10-bit whenever I have to send out an approval copy.
    Is this feasible? Is there something esle I should consider? Or in is it 6 of one when all’s said and done?
    The reason I’m exporting ref files is to send them to Compressor and then to DVD.
    David Eells replied 18 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 4, 2008 at 2:20 pm
    I’m not sure you gain anything rendering in 10 bit with material that was all shot 8 bit… Not as if you improve the video. Might make a difference with any CGI material, but other than that…
    Jerry
  • David Eells
    July 4, 2008 at 2:35 pm
    There is some uncompressed CGI material, but not much. So it sounds like I might want 10-bit when I’m finishing, but it’s not necessary before that.
    I just found it odd that if I rendered at 10-bit and exported a reference mov, the file was relatively small, but if I rendered at 8-bit it was much bigger, which made me think that rendering to 8-bit was a waste of time.
