Activity › Forums › Creative Community Conversations › When to insert B roll?
Posted by Jon Fidler on August 12, 2009 at 12:59 pmHi
I have been watching a lot of short movie featurettes on youtube and have a questions about this style of editing. Im trying to understand when to insert b roll and when to cut to a speaker.
I hope this question isnt too vague. Im aware it depends on the tone of the piece, as well as covering up mistakes or jump cuts when the interview is trimmed of unnessary words or pauses as well as generally keeping things smooth etc.
But creatively when is a generally good place to insert B roll when somebody is talking? Is it usually a casr of illustrating the points the speaker makes?
Also sometimes they will cut back to the speaker after b roll, before the next point is made, why is this?
I know there obviously isnt a definitive answer by any means, but just a push in the general direction as to what I should be aiming for when editing would be very helpful and appreciated.
Chris Bové replied 16 years, 9 months ago 8 Members · 26 Replies -
Mark Suszko
August 12, 2009 at 2:54 pmSometimes you cut back to speaker because that was all the b-roll you had:-) I don’t know of any editor that ever claimed he had “too much” b-roll.
You touched already on most of the points regarding useage of cut-aways. They are at the lowest level, simple “band-aids” or “duct tape” that bridge and cover the joint between two discontinuous clips. That’s the lowest level of how they are used, you see that done in very simple news cutting, for example.
The second level is a literal showing of what the speaker is telling. He’s talking about a polluted lake, you SHOW the polluted lake with his voice behind it. This is mostly to collapse the story told into a shorter time, and add narrative clarity.
A third level is to use the cut-aways to convey emotional subtext. Spooky woods while a guy is talking about fear, time-lapse clouds while talking about heaven, etc. But what if you put the “wrong” b-roll against the narrative, on purpose? Talking about harmony, and showing dissonance, you can create humor where there was none, or make a point about what is true.
The higher levels of usage involve adding the visual and cutting to or away from it as punctuation to what is said, and sometimes to impose a “third meaning” on the synthesis of two other stand-alone ideas, what the guy was saying, and what the visual was showing. Each of those alone have a singular and obvious meaning, but if you combine them right, you synthesize a third, new meaning, one different from either of the stand-alone components.
That’s montage. That’s the power of an edit. To collapse time and space, to define emotional subtext, to suggest things that were never there, to convey a third meaning. That’s where you earn the big bucks.
Tony Stampalia
August 12, 2009 at 3:00 pmHey, Jon.
Yeah, you’ve nailed the illustrative and cosmetic reasons for inserting B. The bottom line is when it feels right and enhances the piece rather than distracting.
You mentioned ‘The Speaker’. Are you asking about cutaways in a narrative or documentary?
In a Doc clarity generally tops the list. So B should be inserted just as you said.
Narratives offer a lot more flavor due to Diegesis – simply the telling of a story by a narrator. Parts of a film can either be diegetic or non-diegetic. Mostly applying to sound, it can also apply to inserts that depict something that is not taking place in the world of the film (a non-diegetic insert). Titles, subtitles, and voice-over narration (with some exceptions) are also non-diegetic.
Here’s an example: In “The Truman Show,” while Truman sleeps soothing music plays, as is common in such scenes. However, after cutting to the control room, we see that the mood music is being played by Philip Glass standing at a bank of keyboards. The shift is from apparently non-diegetic to diegetic, and is a joke.
Whew! Aren’t you glad you asked?
Jon Fidler
August 12, 2009 at 8:04 pmThanks for the excellent responses, what excactly do you mean by punctuation on your final point?
Juris Eksts
August 13, 2009 at 5:34 pmI think that you absorb far more information from an interviewee when you can see their eyes, see the emotion with which they’re speaking.
And when they’re saying something emotionally, that’s the best reason to cut back to them.
When a B roll doesn’t give any more information than the speaker themselves, don’t use it.Juris
Tony Stampalia
August 14, 2009 at 1:00 amThen there’s always B is more interesting than Talking Heads.
Jon Fidler
August 14, 2009 at 3:25 pmThanks for all the answers they have been very helpful.
Can someone exaplain to me, or give a few examples of the idea talked about above about using B roll as punctuation to the points, im a little confused by this.
Tony Stampalia
August 15, 2009 at 2:35 pmEvidently only Marky-Mark. He’s the one using the phrase in a posting filled with generalities and the obvious puffed up to be larger-than-life.
Ask him.
Mark Suszko
August 15, 2009 at 9:53 pmHe was asking me; I’ve been working in the field and too busy to come back to this. Frankly I thought someone else would step in, there’s been a lot of good suggestions/comments so far.
Pick out a middle-length, simple declarative sentence. Repeat it out loud, each time emphasizing a different word. Try it as an exclamation, as a question. We can force similar changes in how the sentence is understood by a listener, in the choices we make during a cutting session. Welles had a good quote about this: “Whether the story has a happy ending or not, rather depends on where you decide to stop telling it”
Say you’re doing a piece about a guy, I dunno, let’s call him “Anthony”, and it is about his assertion that he’s been really good friends with this guy named, um “Max”, and that the current tiff between the two is a simple mistake that will soon clear up. Your shot choices are the medium shot of the guy making his statement, a tighter close-up of his face from a second camera, and various b-roll taken about the same time as the interview, before or after it.
So, you run with just the wide shot, that’s fine, it is a neutral effect as far as in that you didn’t overlay any meaning to it. Break in the middle of the speech at a key moment with the matching close-up, BAM, you’ve called the change out as having some kind of significance. Depending on what “Anthony” is saying at the precise moment of the change, you can reinforce his assertion, emphasize it, or, you can flip the order around, tight to wide, and diminish the power of what he said, without altering a word of it. maybe his face in the close-up looks honest, but the side shot shows a body language that says otherwise. Or maybe the close-up is showing some kind of “tell” that suggests he’s lying. Adding a quick cut-away next to that, say, of his hands wringing or fingers drumming or foot tapping… you just changed how people think they should read this guy. You made him less trustworthy.
It could also be done with the choice of where an L-cut happens, when you cut from a person talking to what it is they are talking about. Depending on how you layer it, people can ascribe a different meaning to the combination than what was there before.
Closeup of Exxon executive: “We are so proud Forbes named us the most ecologically-advanced company this year! ” (Cut away to dead birds gassed by leaks from plant, over this next part. Voice-over continues) “We’ve really shown that working together…) (Shot of crews shoveling up dead birds into sacks for disposal)” …we can improve the environment (cut to shareholder dinner, table full of roast fowl) “…and still serve our shareholders in the best possible way.” (cut back to speaker, full) “We look at it as a win-win partnership.”
Now, that was a very crude example, I didn’t have time to finesse it, I’m late for an appointment, but maybe it gets across the “Punctuation” concept.
