Activity Forums Adobe Premiere Pro when to export at these settings?
  • when to export at these settings?
    Posted by Kent Beeson on September 13, 2014 at 1:37 am
    I usually export my 1920 Pro Res HQ timeline as a Pro res 1920 HQ mov file using these settings –
    so when would choose for video output the 48 bit dial, and when to choose 24 or 32 bit for audio export? I’ve always done the 24 bit for video depth and the 16 bit for audio – when and what advantage for higher video and audio bits? Something to do for DVD or bluray or broadcast or?
    Also what is the native timeline bits – audio 32? Video 48 depth, or what?
    thanks
    Kent Beeson replied 11 years, 11 months ago 3 Members · 5 Replies
  • Ivan Myles
    September 14, 2014 at 3:02 pm
    The video depth is as follows:
    24-bit = 8 bits per channel, three channels
    32-bit = 8-bpc with alpha channel for transparency
    48-bit = up to 16-bpc (use with 10-bit codecs and above)
    64-bit = up to 16-bpc with alpha channel
    The appropriate audio depth will depend on your source material and export requirements. 16-bit is typical, although 24-bit or more might be appropriate for high quality and/or high sampling rates. Floating point audio is used to prevent clipping and allow levels to exceed the maximum. You would typically only use floating point audio with intermediate files prior to final delivery.
    Higher bit depth gives greater fidelity. An 8-bpc depth provides 256 graduations from zero to max. By comparison, 10-bpc provides 1024 graduations over the same continuum, and therefore there is smaller difference from one graduation to the next. A simple example is the number of gray shades on a scale from black to white: 8-bit provides 254 in-between shades while 10-bit provides 1022 shades. The end points (black and white) are the same in each case. 10-bit video is often used in colorization when moving between RGB and Y’CbCr (YUV) to minimize artifacts such as banding and blocking.
  • Daniel Sametz
    September 14, 2014 at 4:15 pm
    So for dslr video 24 bit is more than enough right?
  • Ivan Myles
    September 14, 2014 at 6:16 pm
    24-bit audio is sufficient. 24-bit video may or may not be appropriate depending on the effects applied and overall workflow. The conservative choice is to use the 48-bit setting and enable Maximum Depth on export, even if there is no ultimate impact on quality. It’s a 10-bit codec, so you might as well export at the same depth.
  • Daniel Sametz
    September 14, 2014 at 8:44 pm
    Thanks 🙂
  • Kent Beeson
    September 15, 2014 at 4:39 am
    helpful stuff – thanks very much
