Activity Forums Compression Techniques When to convert into “I Frames Only” video stream
  • When to convert into “I Frames Only” video stream
    Posted by Jay Agoglia on October 25, 2012 at 3:43 pm
    HI Cow!
    This is a general questions: In the production chain of file delivery, when do you want to convert a spot into I Frames only?
    For Instance if I have to take an SD MPEG file at lets say 4:2:2 and 25mbps and trans-code to 4:2:0 15mbps ; Do I want the higher quality file (25mbps) in I frames or the very last file top be converted from a GOP to I Frames?
    Thank you for your help!
    -Jason A
    Jason Agoglia
    QC Manager
    On The Spot Media
    Craig Seeman replied 13 years, 10 months ago 2 Members · 1 Reply
  • Craig Seeman
    October 27, 2012 at 1:24 pm
    Delivery to what?
    Sorry but that makes all the difference.
    GOP, at a given data rate, is generally more efficient. GOP can be much higher quality that IFrame.
    IFrame tends to be better intermediary for some uses because it’s easier for systems to process since it isn’t reconstructing frames by using B and P frames looking for information.
