Activity › Forums › Apple Final Cut Pro Legacy › When to add logging info to Canon 5D footage?
  • When to add logging info to Canon 5D footage?
    Posted by Jeffrey Buras on December 1, 2009 at 8:46 pm
    When working with a Canon 5D, should I add logging info to my clips before or after I transcode to ProRes? I would think I would want that data in the files as soon as possible so that if I have to transcode again, that information is preserved in the original file. Am I being silly?
    Here are my two proposed workflows:
    1) Import H.264 files into a Final Cut Pro project
    2) Review clips and add data about reel, angle, shot/take, etc.
    3) Transcode H.264 clips to ProRes using Compressor
    4) Import ProRes clips into a new Final Cut Pro project
    5) Edit
    1) Transcode H.264 clips to ProRes using Compressor
    2) Import ProRes clips into a Final Cut Pro project file
    3) Review clips and add data about reel, angle, shot/take, etc.
    4) Edit
    There will be no framerate conversions.
    Jeffrey Buras replied 16 years, 10 months ago 3 Members · 3 Replies
  • Michael Gissing
    December 1, 2009 at 10:18 pm
    Unless you need to go back to the FCP project with H264 files, I don’t see any advantage in the first workflow.
    As you won’t be able to smoothly play in FCP until transcoded, I would find it easier to batch convert first and just bring the ProRes into FCP before adding reel & shot data.
    Even though you intend to edit at 30p don’t forget to convert the audio to 48khz
  • Brandon Adams
    December 1, 2009 at 11:04 pm
  • Jeffrey Buras
    December 2, 2009 at 2:14 am
    Wow, Brandon. If this was already released, this would be exactly what I need. We’re shooting this weekend with an on-site editor, so it won’t help for this shoot but I’ll keep an eye on it for future projects. Thanks for the tip!
