Activity Forums VEGAS Pro When SV is building peaks
  • When SV is building peaks
    Posted by Brandon Brand on October 19, 2009 at 9:05 pm
    Hi all
    When importing a video in the timeline Vegas normally shows at the bottom left corner that it is building peaks. Why does Vegas do this? Also i’ve noticed that if i cancel it it can still be editered but you can’t see the audio levels. Is there a way i could restart the building peaks without importing the video in the timeline again?
    Brandon.
    Brandon Brand replied 16 years, 10 months ago 2 Members · 2 Replies
  • D. Eric franks
    October 19, 2009 at 9:11 pm
    You figured it out: the audio levels or waveform is the “peaks” Vegas is drawing, converting the audio information into a visual record of the loudness. It’s saved to a special SFK file (*.sfk) in the media’s directory. They are small and you can ignore them – or delete them and rebuild them later, no worries.
    View > Rebuild Audio Peaks (Shift+F5)
  • Brandon Brand
    October 20, 2009 at 10:41 am
    Great!
    thanks Eric 🙂
