Activity Forums DaVinci Resolve When Split Clip manually Clip node affects all clips?
  • When Split Clip manually Clip node affects all clips?
    Posted by Jim Larsson on April 19, 2012 at 9:33 am
    I am splitting a video file manually in DaVinci Resolve lite (mac) with the Split Clip tool in the conformtab. After doing that when choosing a clip in the Colortab and grading the clip node (not the track node) the node affects all clips in the color tab as if it all was a long single clip.
    How do I get this working as separate nodes for each clip?
    Jason Brown replied 13 years, 6 months ago 4 Members · 4 Replies
  • John Michaels
    April 19, 2012 at 6:22 pm
    In the Color tab, select your clips, right-click, and choose “Batch Unlink.” That will make each clip independent despite being from the same source.
  • Jean-francois Carrier
    January 4, 2013 at 5:45 pm
    This option are always in the version 9? I’m searching this option and I can’t find this …. :S
  • Jason Brown
    March 18, 2013 at 10:51 pm
    I am also searching for this in version 9. Any luck finding how to batch unlink split clips?
  • Jason Brown
    March 18, 2013 at 11:11 pm
    Issue resolved — in the color timeline, select the clip and right click. Enable “use local grades”.
