Activity › Forums › Event Videographers › When shooting a Wedding over 60 minutes?
  • When shooting a Wedding over 60 minutes?
    Posted by Ralph Hajik on June 19, 2005 at 9:26 pm
    Hi Videographers,
    I’m fairly new to the business of videography. I would like to know what do you do when the Wedding Ceremony is longer than the 60 minute tape you have in the camcorder. I like to set up a tri-pod and start recording a few minutes before the ceremony starts and keep recording to capture from the front side of the alter (45′ angle)as the groom meets the bride. Then use a second camcorder to take angle shots. But what happens when your #1 camcorder at the alter runs out of tape. I was told that it’s best to record in standard mode instead of LP mode. Any comments will be very much appreciated.
    Ralph Hajik
    Westmont, IL
    Thaxter Clavemarlton replied 21 years, 2 months ago 12 Members · 17 Replies
  • 17 Replies
  • Jeff Carpenter
    June 20, 2005 at 1:32 am
    Is this DV?
    You can buy an 83 minute DV tape.
    https://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=240000&is=REG
    The tape is a little thinner so they can fit it all in there. You shouldn’t use them as master edit tapes because of that, they may wear out faster over the years than a regular tape.
    But I’ve used a ton of them as shoot tapes and I’ve never had a problem. It’s certainly a lot better than shooting in LP mode.
  • Ralph Hajik
    June 20, 2005 at 5:51 am
    Hi Jeff,
    Thanks for the information. That will ework just find. Another solution is to invest in the FirePro so I can record tapeless.
    Ralph Hajik
    Westmont, IL
    Canon GL2
  • Tom Maloney
    June 20, 2005 at 11:32 am
    one of the reason I use a Panasonic DVC200, can shoot up to 3 hours
    good luck
    Tom
  • Doug Graham
    June 20, 2005 at 2:17 pm
    Solutions:
    – use 83 minute tapes
    – record in LP mode (not recommended. The use of LP can increase the chances the tape will not play in a different deck or camcorder)
    – use a Firestore or other disk recorder
    – and the cheapest of all: Simply stagger tape changes between your front and back cameras. Make sure the other camera has a good, steady shot for the 30 seconds or so it’ll take you to change tapes. This requires that you have access to your camera, of course…you might not be able to service an unmanned camera on the altar.
    Regards,
    Doug Graham
  • Mark Postma
    June 20, 2005 at 4:01 pm
    One more option may be to use a remote to pause the front camera during times you don’t need the shot. Granted, you can’t track how much record time is left remotely, but you could stagger WHEN you are recording if your remote has a long enough reach.
    Postal
  • Bouncing Account needs new email address
    June 21, 2005 at 12:51 am
    Can’t believe nobody mentioned this one:
    A slick trick is to connect the first (A) camera via FireWire to a second (B) inexpensive home-video-type DV camcorder with a second tape at the ready (B will be in “VTR” mode so it will “see” the video/audio from the A camcorder coming down the FW).
    After set-up, power down the B camcorder until just before you need it.
    Have a volunteer helper stand-by at the 1-hour point and turn on the B camera and put it into RECORD just before the tape in the A camera runs out (you’ll have an “overlap” for a couple of minutes on both tapes).
    I have several inexpensive Dv camcorders that I bought at pawn shops for under $200.
    These work great as secondary record “decks” for this kind of location need.
    The VIDEO/AUDIO quality on the B camera will be IDENTICAL to the A camera because all you are using of the inexpensive camcorder is the “tape deck” section and not the image section.
    It will appear that you simply were able to record for 2 hours on the same camcorder.
    (And I’ll chime in again with the “NEVER use LP speed” for anything at any time. It is UN-reliable.)
  • Ralph Hajik
    June 21, 2005 at 5:00 pm
    Hi Matt,
    If your shooting the event by yourself, I beleive that you would power up the B camcorder and put it on pause until you need it. Trying to capture with a cam in hand and a remote inyour pocket, I guess that will work. Maybe the 83 minute or the Firestore Pro 4 would work just as good.
    Guys, Thanks for the options and happy videotaping.
    Ralph Hajik
    Westmont, IL
  • Doug Graham
    June 22, 2005 at 5:27 pm
    Not on pause! The camcorder will shut off automatically after about five minutes to prevent undue wear on the tape.
    Regards,
    Doug Graham
  • Vito Defilippo
    June 23, 2005 at 3:51 am
    Do weddings where you are last so long? Here in Montreal, I change the tape just before the bride’s entrance to the church, press record, and let it go. Not once in 30 weddings have I had to change the tape before they exit the church. Even with Italian catholic weddings with communion…
    I suppose if I had to, I would just change it during the signing, or during the communion. I always cut those short in the editing anyway. Do you really need to chain on another camera, look for volunteers, etc? Great idea to fix the problem, but a bit of overkill IMHO.
    I use the Panasonic 63 minute tapes.
  • Peter Ralph
    June 23, 2005 at 4:40 am
    Here in Colorado I have had Catholic weddings extend to 60-75 minutes 3 times. Two of those times I was told the wedding would last for 45 minutes, 60 minutes max! If a wedding is scheduled to go over 45 minutes I run 83 minute tapes. Cheap insurance
