Activity › Forums › Adobe Premiere Pro › When rendering the footage before exporting the aspect ratio appears to change.
  • When rendering the footage before exporting the aspect ratio appears to change.
    Posted by Dave Andrade on August 4, 2013 at 1:56 am
    I import 16 by 9 footage (1920 by 1080) and then I interpret the footage as such (square 1.0 pixels). When looking at the preview monitor it is fine, but when I render the footage, it puts bars on the top and bottom of the newly rendered footage.
    I haven’t had this issue before, so I know/assume I changed or am missing something. The sequence size matches the footage, and the pixel aspect ratio matches too.
    What am I missing?
    Dave Andrade replied 13 years, 1 month ago 3 Members · 6 Replies
  • Ann Bens
    August 4, 2013 at 8:33 am
    What are your export setting preferably a screendump.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Dave Andrade
    August 4, 2013 at 9:04 am
    Well, that’s the thing. I haven’t even exported yet. However, is that the issue?
    It is Canon DSLR footage and when I went to check the export settings now, I noticed the source footage was 8 pixels short of the 1920 by 1080 on the height, but I’m sure that doesn’t factor in.
    Anyway, it is h264 – video is the square aspect ratio 1.0. So it’s consistent wherever I look. That being said, should interpret the footage as widescreen then? Again, it looks fine importing, looks fine color correcting, but when the bar turns red and I attempt to render, it renders, and then compresses the height.
    I never thought about the export settings though…
  • Ann Bens
    August 4, 2013 at 10:28 am
    when does the bar turn red.
    dslr footage shows yellow.
    make a new sequence by dragging a clip into the new item icon.
    See if that will work.
  • Tero Ahlfors
    August 4, 2013 at 10:57 am
    [Dave Andrade] “Well, that’s the thing. I haven’t even exported yet. However, is that the issue? “
    What is your preview codec in the sequence settings?
  • Dave Andrade
    August 4, 2013 at 11:47 am
    Unfortunately, now I cannot recreate it! I shut down my computer for a little bit and now when accessing the same projects and footage, I cannot cause that to happen again.
    I adjusted the settings for the preview recently but now I cannot even recreate that, no matter what preview I choose in the sequence settings.
    Thanks for the assistance everyone. I apologize. I am going to go under the assumption that maybe it was an incorrect dimension entered under the preview field. It’s the only thing that makes sense at this point.
  • Dave Andrade
    August 5, 2013 at 1:27 pm
    To anyone who assisted me or anyone reading this who ran into a similar issue I determined it was the export settings as has been suggested. For this project it was set to DV. I. changed to uncompressed and it worked great.
