Activity › Forums › VEGAS Pro › When rendering project, it stops at 57% and it says system is low on memory, close other applications…
Peter Popovici replied 16 years, 2 months ago 6 Members · 13 Replies
Nhat Nguyen
May 23, 2010 at 12:35 amHiJohn,
There’s no yellow question mark at all in my Device Manager…the .m2t play fine with Nero showtime and premiere pro also load up properly..only with Vegas x64 in WIN XP Pro x64.
Main Concept MPEG2 issue in Vegas?
Thanks in advance for any suggestion except changing OS to Vista or Win7 -
Dave Edwards
June 20, 2010 at 12:11 pmHi: a trick I pull when Vegas refuses to render is as follows:
1 Save your problematic project as
2 Select the entire timeline and hit delete
3 Open a second instance of Vegas with the problematic .veg file
4 Select the entire timeline and copy and paste this into project
5 Try to render thisI’m using Windows 7 64 bit,- but this may be worth a try as it has got me out of a hole several times.
Peter Popovici
June 21, 2010 at 12:25 pmThank you DAVE, I solved it by rendering the edited AVCHD project into MP4. I will consider your solution as well.
