Activity Forums Adobe After Effects When pre-composing a 3d object, can you retain the z-axis values? Mine gets flattened.
  • When pre-composing a 3d object, can you retain the z-axis values? Mine gets flattened.
    Posted by Robert Maric on May 10, 2013 at 8:50 am
    Hey there,
    I am using AE CS6
    I have a few layers that are spread out over the z-axis. When I pre-comp them they flatten out to have the same z-axis. Is that normal? I have collapse transformations and 3d enabled for the layer.
    Cheers
    Robert Maric replied 13 years, 3 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    May 10, 2013 at 9:58 pm
    [Robert Maric] “I have collapse transformations and 3d enabled for the layer.”
    You should have Collapse Transformations switched on for the nested comp – this is absolutely necessary to each embedded layer’s 3D-ness into the ‘final comp’.
    BTW, it may not be necessary to switch on Collapse Transformation for the layers in the precomps.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Robert Maric
    May 11, 2013 at 1:51 am
    Thanks for taking the time to reply. I really appreciate it.
    I was making a mistake – I was turning motion blur on instead of enabling collapse transformations 😉
    Works now!
    Thanks again
    Rob
