Activity Forums Adobe After Effects When placing image on compostition how can you default its duration…
  • When placing image on compostition how can you default its duration…
    Posted by Chad Ramos on March 17, 2010 at 5:37 pm
    Currently when drage an image from my project frame to my timeline in any given compsition, the duration of said image is equal to the duration of said composition. I would like to change that value so that when I do drag in image into the timeline it is not super long but shorter. Something in the range of 5 seconds. Is there a way to make this happen by default instead of have to change it after it has been put into a timeline.
    Regards
    Chad
    Chad Ramos replied 16 years, 5 months ago 2 Members · 2 Replies
  • Todd Kopriva
    March 17, 2010 at 7:21 pm
    from After Effects Help:
    “The Still Footage preference setting (Preferences > Import) controls the default duration of layers that use still footage items as their sources. By default, when you create a layer with a still image as its source, the duration of the layer is the duration of the composition.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Chad Ramos
    March 17, 2010 at 7:24 pm
    Thank you
    Regards
    Chad
