Activity Forums Adobe After Effects When morphing shapes, the final shape jumps out of position and I don’t know why
  • When morphing shapes, the final shape jumps out of position and I don’t know why
    Posted by Steve Miller on April 12, 2016 at 12:18 am
    Hi all,
    I’ve been playing around with morphing shapes using paths and I’m getting a glitch where when the morph finalizes, it jumps out of position on the last key frame.
    So I make two shape layers, convert the paths to bezier paths, key frame the initial shape’s path, then I go to the other path and keyframe it, copy it’s key frame then paste back into the first shape’s path. Every tutorial I’ve come across shows this and it works fine with text… but shapes… not for me.
    Please see attached images of my screen.
    Any help would be great!
    *steve
    I’ve selected the original position of the circle and square here in this last image to show how it’s jumped out of place.
    Roei Tzoref replied 8 years, 2 months ago 5 Members · 5 Replies
  • Soham Jani
    April 12, 2016 at 2:41 pm
    If it’s a keyframe problem you might have to manually edit that keyframe, at the last frame. But it seems something a little different here. But try manually animating it, though it’s a pain but it might pay off..
    \”It\’s all around us Neo, temporary constructs of time…..\”
  • Steve Davies
    July 4, 2018 at 1:17 pm
    Hi Steve, did you find a solution to this? I am struggling too!
    Digital Designer
    stevedavies.io
  • Daniel Lindner
    July 4, 2018 at 2:37 pm
    If I got you right, you might wanna look at this. I put the time indicator where I think your problem is dealt with:
    https://youtu.be/iLd-5x5KhyA?t=6m7s
    Best
    Daniel
  • Steve Davies
    July 5, 2018 at 8:50 am
    Hi Daniel
    Thanks for this, was happy to see it happen with someone esle, but his solution doesn’t work. I wonder what I am doing wrong?
    Digital Designer
    stevedavies.io
  • Roei Tzoref
    July 7, 2018 at 12:32 pm
    Steve, when you paste a path, you need to make sure it’s in the same place or else it will shift. in the GIF you provided, you clearly have the circle to the right of your square and that’s why you are seeing a shift. simply select the path property and move all the circle vertices to be aligned with the square ones and it will animate in the same place.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
