Activity › Forums › Blackmagic Design › When is the HyperDeck Shuttle Shipping?
Posted by Peter Corbett on June 13, 2011 at 6:07 amLots of retailers showing shiping early June for this. Any word from BMD when it is actually shipping?
Peter Corbett
Powerhouse Productions
http://www.php.com.auColin Hubick replied 15 years, 2 months ago 6 Members · 7 Replies -
Alex Gerulaitis
June 14, 2011 at 2:13 amIn lieu of official response, it’s late June according to BMD distributor as of 1 week ago. It also depends on when and if you pre-ordered. The few of them that I ordered back in early May will likely ship sometime in July.
Alex (DV411)
Peter Corbett
June 14, 2011 at 7:24 amThanks Alex,
Just weighing up whether to spend the money (as cheap as it is) on the HyperDeck or put it towards a SD PIX240 or similar. The unit is cheap but the SSD’s will cost more than the recorder. But then the entry price is sssssoooooooo attractive.
Peter Corbett
http://www.php.com.au -
Kristian Lam
June 15, 2011 at 12:48 pmHi Peter,
HyperDeck Shuttle is shipping now.
regards
Kristian Lam
Blackmagic Design -
Peter Corbett
June 15, 2011 at 8:49 pmThanks Kristian,
Can any SSD be used on the deck, or are there recommended ones?
Cheers,
PeterPeter Corbett
Joshua Helling
June 21, 2011 at 6:19 pmWe’ve tested some of these
1) OCZ Vertex 3 240 Gb
2) Kingston V+ 64GB & 128GB
3) Crucial C300 256GB
4) Crucial M4 256 GbOne thing we’ve noticed is that it seems drives with the Vertex 2 chipsets seem to do some sort of compression on the fly which severely limit speed. The Vertex 3 chipsets do a lot better. The Kingstons i’ve used at several shows and work solidly. Crucials are nice too.
As we move forward we will continually test new drives and get feedback from the customers on drives that are working and not working.
Hope that helps.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc. -
Duki Dror
June 26, 2011 at 7:14 pmHow do you separate the audio sdi from the video when you need to send it to 5.1 surround system?
When will it be available at b&h? -
Colin Hubick
July 6, 2011 at 8:10 pmHello, with regards to the Hyper Deck Shuttle, does this unit have the ability when conected via HDSDI to cue it’s record from the HDSDI output from the camera?
Colin
