When is Black Black?
Posted by David Ludwig on April 20, 2009 at 4:24 pmI just rendered a spinning logo and ProType text on a black BG. Looks great in Vegas (8c), but in Windows Media Player the black BG looks not quite black and is surrounded by a true black border in the player.
How do I make sure that my BGs are black black?
Thanks.
David Ludwig replied 17 years, 5 months ago 3 Members · 13 Replies -
Mike Kujbida
April 20, 2009 at 4:58 pmIt sounds like your blacks are at 16-16-16.
Make sure they’re at 0-0-0. -
David Ludwig
April 20, 2009 at 6:23 pm -
Mike Kujbida
April 21, 2009 at 12:33 amI’m not sure what to say David.
I recreated this title, rendered it out as DV-AVI, MPG-2 and WMV (3 mbps) and brought all 3 back into Vegas.
They all looked identical on the scopes and I didn’t see anything like you’re describing.
My suspicion, and that’s all it is, is that it’s either your monitor or (more likely) Media Player and not Vegas that’s at fault. -
Mike Kujbida
April 21, 2009 at 12:49 amDavid, out of curiosity, what format and setting did you render to?
David Ludwig
April 21, 2009 at 1:55 amrendered to WMV.
best
quality VBR
872×480
PAR=1
29.97
keyframe every 3 sec
quality 100%
stretch to filli guess it’s a non-issue. i use WMV as an intermediate on my way to Flash. there are no borders around the flash movie, i was just concerned that i may have overlooked something in vegas.
thanks again for your help.
David Shirey
April 21, 2009 at 2:16 pmI don’t know if this is related at all, but I have always found Window’s Media Player, and subsequently any other media players that just act as a an intermediary for window’s built in video playback, to be a little random. I haven’t tried in Vista but ever since XP first came out, I’ve been able to play the exact same file and have it look two entirely different ways. Almost as though there’s a brightness/contrast filter that sometimes gets applied to playing videos. If I set up a series of videos to play, or the same video playing several times in a playlist, it pretty much does it to every other instance like clockwork. I don’t know if that’s a common problem, but perhaps it could be what was affecting David? Either way, my solution has always been to not use (or at the very least not trust,) WMP.
