Activity Forums Adobe After Effects When is 3:2 pulldown necessary?
  • When is 3:2 pulldown necessary?
    Posted by Erin Patrick on February 20, 2007 at 11:16 pm
    Is there any reason to remove pulldown if you are not rotoscoping footage (when transferred from film)?
    When you are just adding graphics on top of the footage, it isn’t necessary, correct?
    Thanks for the insight.
    Jack Hilkewich replied 19 years, 7 months ago 2 Members · 3 Replies
  • Jack Hilkewich
    February 21, 2007 at 4:45 pm
    I am about to be adding a CG character to a live video plate. The video will be shot with a HD camera and at 24p. I will be doing the compositing as well, in AE. Now I am extremely new to this. What should I be doing in terms of this pull down? We will be using Bou Jou to track.
    What should I be doing in Maya before I render in order for it to match the video(I mean in terms of frame rate/ field versus frames rendering).
    I hope you can help a poor guy out!
  • Jack Hilkewich
    February 21, 2007 at 6:12 pm
    Thanks for the reply.
    Yeah I can set Maya to run at the same frame rate. Not sure about rendering fields or frames though, I will check that out.
    So I ask for the editor to remove the pull down? When I get it, what will be different from not having the pull down removed? and when I render out from AE do I add the pull down in? If so How do I do that?
    Sorry for being such an idiot, but tech things aren’t really wired in my brain.
  • Jack Hilkewich
    February 22, 2007 at 10:41 pm
    Thanks for all your help Dave!
