Activity › Forums › Adobe Illustrator › when I shrink a object it get distorted
Adam Ferguson replied 9 years, 7 months ago 16 Members · 28 Replies
Shawn Rossi
October 7, 2013 at 5:05 pmGo to Transform Panel > Uncheck ALIGN TO PIXEL GRID.
I was having the same issue in Illustrator CC. This fix will apply to CS5 and CS6. The big pain is that this is on by default and I do not see how to turn if off in the Prefs. I have to manually uncheck this box for each new document I open.
Moooo!
Rossi -
Alex Dickson
December 3, 2013 at 11:38 pmI had the same problem.
Enable Scale Strokes & Effects.
Worked a treat. Cheers!
Vanessa Sande
April 15, 2014 at 1:02 pmThank you Mat, this fixed it. i was getting insane in a whole file i’d only one tiny object with snap to pixel activated and it was messing with everything around. i still dont know how it became activated. Again Thank you very much you saved me from having to start all over again an lose 4 hours of work 🙂
Dibyendu Deb
July 19, 2014 at 12:24 pmNo! I am still having the problem. When I am reducing the object to 23×23 px it gets distorted and remains same even when expanding to the previous size! I have followed all the suggestions you made.
Dibyendu Deb
July 19, 2014 at 12:58 pmOk I did it! just with one command after using all previous settings suggested by you; it is flatten transparency 🙂
Tannie Low
February 19, 2015 at 11:50 pmI tried everything, but only Rossimo’s recent suggestion worked – unchecking Align to Pixel Grid in the TRANSFORM window panel (Window > Transform). I had it disabled everywhere else but here. Thanks!!
Andre Van herk
March 2, 2015 at 1:02 pmTo all the quick and dirty solution to this problem
if your artwork is distorted when scaling make a symbol of it and you can scale it to the size of an ant
all will be in placehope i helped out a lot of you
greetings Andre van Herk
Adam Ferguson
January 31, 2017 at 9:36 pmNice! I have run all over the internet this afternoon trying to figure out what the problem was. This solved it! Thank you!
