Activity › Forums › Adobe Illustrator › when I shrink a object it get distorted
Adam Ferguson replied 9 years, 7 months ago 16 Members · 28 Replies
Leandro Petreca
February 23, 2011 at 10:51 amI reinstall illustrator and delete my preferences.. And now its like you said Les.. Thanks
Wendy Wear
January 28, 2012 at 10:21 pmhoping someone is following this thread..
i have the same issue ..
on a PC, Illustrator CS5 .. have deleted my entire Adobe Illustrator CS5.1 Settings folder and had it regenerated .. but still can’t resize a drawn object without it distorting.text resizes fine, but
i have drawn a circle, using the outline color only, no fill.
i have added some effects .. blur and shadow.
if i try to transform to a smaller dimension (using % or bounding box handles), the circle becomes thicker
i have uploaded a visual showing this..
this is driving me crazy 🙂
any suggestions appreciated.thank you
Vincent Rosati
January 29, 2012 at 5:38 amAre you using a brush?
If so, expand before resizing, or in Preferences enable Scale Strokes & Effects.Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Wendy Wear
January 31, 2012 at 12:09 amTHANK YOU Vincent !
I already had ‘Scale Strokes & Effects’ checked..
but I unchecked and rechecked it .. and it works now.I’m so thankful for forums like this, and people like you, who take the time to keep me from going more looney than I already am 🙂
thanks again !
wendy
Mat Taylor
July 18, 2012 at 9:48 amI had this problem. The answer is very simple. What is happening is that you have ‘snap to pixel’ activated for your object. when you scale up or down, the points in the objects are snapping out of position to the nearest pixel. switch the snapping off and itll be ok again.
mat
Anthony West
October 8, 2012 at 8:01 pmThanks Vincent! This solved my issue as well.
Cheers,
Anthony -
Robert Koh
July 4, 2013 at 11:40 pmI am still having this problem. I’ve turned off snap to pixel grid. I’m using CS6 on mac. I have no strokes or effects. I’ve tried it with/without scale strokes effects and still get distortion. Any idea what’s going on? I don’t ever seem to remember having this problem before cs5…
Robert Koh
July 4, 2013 at 11:41 pmI am still having this problem. I’ve turned off snap to pixel grid. I’m using CS6 on mac. I have no strokes or effects. I’ve tried it with/without scale strokes effects and still get distortion. Any idea what’s going on? I don’t ever seem to remember having this problem before cs5…
Joyce Soo
September 6, 2013 at 8:32 pmI have the same problem with CS6 too. I figured out the temporary fix, is to restart illustrator, and the problem is gone.
