Activity Forums Adobe Premiere Pro When I “replace with AE composition” I get a blank comp in AE.
  • When I “replace with AE composition” I get a blank comp in AE.
    Posted by Andreas Yannakopoulos on September 6, 2013 at 8:49 am
    Hello people,
    I’d appreciate your help on this. I am working with Premiere Pro cs6. I am trying to send a clip in AE by selecting it and go to File/ Adobe Dynamic Link/ Replace with After Effects Composition.
    After Effects opens and contains a comp in the project pane but it is blank. my clip is not there in the timeline pane. Also the clip in Premiere is offline.
    The thing is that it was working fine. The only thing that happened is that I did some organizing in both Premiere and AE (deleted some Comps – moved some sequences in folders etc.) I don’t think this could cause this, but again in case it did I tried new projects both in Premiere and AE and it still didn’t work.
    I went through the settings and I researched on the net but couldn’t find something. I tried a clean installation but still the same.
    Any ideas?
    Thank you,
    Andreas
    Andreas Yannakopoulos replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
