Activity › Forums › Adobe After Effects › When I render time-reversed composition, it gets messy all the time. Why? Is it glitch?
  • When I render time-reversed composition, it gets messy all the time. Why? Is it glitch?
    Posted by Yousuke Tadokoro on February 18, 2013 at 1:10 am
    Hello. I am using After Effects cs6.
    When I render my time-reversed composition, it gets messy.
    For example I time-reverse a composition that has track-matte layers. I preview it in AE and it looks good,
    so I render it.And The rendered movie is corrupted, because its track-matte isn’t time-reversed.
    Have you ever seen this kinda situation?
    Is it glitch? Is there any rules, something like “DON’T RENDER TIME-REVERSED LAYERS, OR YOU WILL BE IN BIG TROUBLE.”
    I always use time-reversed compositions, because I always need to make loop movies, so I have to use time-reverse,
    but it is really unreliable.
    Yousuke Tadokoro replied 13 years, 7 months ago 3 Members · 3 Replies
  • Vishesh Arora
    February 18, 2013 at 4:18 am
    Yousuke
    I have never heard of any problem like this before, May be a its a bug. Do have the latest update installed?
    After Effects CS6 (11.0.2)
    Also if the RAM preview is fine then you can save the RAM preview:
    Go to Composition> Save RAM Preview and see if it works.
    Try using Set Matte Effect instead of Track Mattes and check whether the same problem occurs or not.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Mathew Fuller
    February 18, 2013 at 6:57 am
    Just pre render out the track mattes as footage. Import and replace.
    My Work:
    https://www.morecompletefx.com
  • Yousuke Tadokoro
    February 19, 2013 at 10:42 am
    Thank you for your advice.
    My sequence image is png files, and I know pre-rendered video works fine.
    If I apply time-remap and reverse the 2 initial key frames, it works fine.
    I don’t know why it works but time-reverse does not.
