Activity › Forums › Apple Final Cut Pro Legacy › When i import my video and audio is not synced properly
  • When i import my video and audio is not synced properly
    Posted by Harlan Richter on June 30, 2005 at 10:21 am
    I am having a periodic problem when I import footage into Final Cut pro.:
    Background: Camera Sony VX2100, Powermac 1.25gz Duo, Powerbook 1.5gz, FCPDH 4.5, External hard drives both Maxtor and Seagate, both 7200 RPM Firewire, Sony DSR-30 DVCAM.
    Situation:
    I shoot a wedding with the vx2100 on SP ( 1 hour)
    I import the tape on a DSR-30 via firewire
    I have also imported it directly to the computers from the camera with the same occurrence
    Problem: The audio is off 20 to 100 frames from the video. In other words is not synced.
    The tape plays and sounds fine on the camera and DSR-30. It becomes unsynced during the import.
    I fix it by resyncing it, but is there a permanent fix?
    Harlan
    Harlan Richter replied 21 years, 2 months ago 3 Members · 4 Replies
  • Mantrafilm
    June 30, 2005 at 10:49 am
    when you play back the imported footage(=when you notice it to be out sync) where does the video signal go through, and where does the audio signal go through?
  • Ted Kusio
    July 1, 2005 at 3:02 pm
    When I have this problem, it’s playing on my computer, going through an AJA IO, and either onto my monitor, or to my Beta deck. Worst part is it’s not a straight “it’s off by X frames” problem, and sometimes it seems as if it’s off more than other times, so I get it lined up PERFECTLY, but then re-edit some other area and the audio is out os sync… again.
    And what I see/hear on my computer during editing is pretty much what I get on tape.
    Does that help?
  • Harlan Richter
    July 2, 2005 at 12:14 pm
    Some tapes come in fine and some are off synced. I am hearing the audio from the speakers in the computer.
  • Harlan Richter
    July 2, 2005 at 12:16 pm
    Once I resync it is ok thoughout the segment. The question is why it is off in the first place.
