When I export something from final cut to after effects Edit in after effects and put back into final cut the footage is lighter and slightly foggy
When I export something from final cut to after effects Edit in after effects and put back into final cut the footage is lighter and slightly foggy. am I doing something wrong or is this how it always works? im exporting in and out of both with the exact same format… what am I missing?
Thanks!!!
