Activity Forums Business & Career Building When HD really isn’t HD
  • When HD really isn’t HD
    Posted by Chris Blair on September 11, 2009 at 1:46 am
    In the last few months our clients have started asking for HD on TV commercial projects. Most of the HD stuff we’ve done in the past has been for display specific purposes. Things like video projected on a wall of a casino, video played back on specific in-store HDTVs, Kisok Information systems and stuff like that.
    Recently we’ve done a couple of HD TV spots and I’ve been amazed at how few broadcasters accept HD for spot delivery.
    In our market, only one accepts it but they require what they call “center-cut” HD, because for SD playback, the station (and the cable outlets that rebroadcast their signal) just place the HD spot full-frame inside the SD frame (cutting off 17% of the left and right side of the HD content).
    They said this is standard in the industry and I certainly can’t argue since I have no clue if it is or not. But it seems crazy to me to do that to 16:9 material that was designed for widescreen.
    Is this common?
    I’ve also been amazed that with all the hype about HD, that it seems the majority of local broadcasters are likely up-rezzing SD TV spots for playback in HD. In a world where most TV stations and cable outlets can’t dub or encode an SD spot correctly for playback in SD, I can’t imagine what’s happening to SD spots being up-rezzed to HD.
    So why bother producing in HD if only one of 7 or 8 outlets for media distribution will accept it…and they’re going to cut off a third of your content when it airs in SD in viewers homes? For the projects we’ve done, there is a LOT of extra work in creating both an HD and SD version, especially considering the “center-cut” requirement for the HD delivery.
    Any thoughts or real-world workflow suggestions on this?
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
    Rafael Amador replied 16 years, 12 months ago 11 Members · 18 Replies
  • 18 Replies
  • Grinner Hester
    September 11, 2009 at 2:47 am
    It’s quite common. Our local cable company often boasts about their HD service. The dude who came out to “upgrade” us actually went into a pitch telling me how it was uncompressed and componant.
    It comes into the house via coax. lol
    I have an Avid Adrenaline so HD is not an option as an end result here yet but the truth is, I’ve no need to upgade yet as all of my clients are SD. My biggest client, a satallite network, airs composite mono and sadly, man I don’t think most who watch it even know or care. I know of only one station here in town that would accept an HD tape and they’d transfer it to beta if I turned it in that way. HD is much more of a buzz word than a requirement in many cases. Much like the word Avid was in ’95. This will change over time but it will be some time before it does.
  • Arnie Schlissel
    September 11, 2009 at 3:39 am
    [Chris Blair]
    So why bother producing in HD if only one of 7 or 8 outlets for media distribution will accept it.”
    1- Because your client asked you to. They may not really need it, but, hey, it’s HD. It must be better, right?
    2- Because your client asked you to. There may be an outlet that will be using it in HD, and the client wants to take advantage of that.
    3- Because in a couple of years, everything will be HD, anyway.
    [Chris Blair] “For the projects we’ve done, there is a LOT of extra work in creating both an HD and SD version, especially considering the “center-cut” requirement for the HD delivery.”
    Try & find a way to design your text & graphics for the center cut. IOW, keep all of the text inside where the 4×3 title safety will be. Keep any infographics & logos inside that area. Things like color mattes, patterns, textures, those can go to the edges to fill out the 16×9 frame.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Ron Gerber
    September 11, 2009 at 2:15 pm
    It’s all tied to budgets. Generally speaking the people writing the budgets and approving the budgets look a one thing, the bottom line for the company. Since most stations (cable & broadcast) are still primarily viewed in an SD environment I suspect they simply don’t want to spend the money on new equipment especially with ad revenue down (think automotive).
    Once the number of HD viewers outnumber the SD viewers you’ll see things change in a hurry. Or in individual markets if enough big dollar advertisers demand it, it might change sooner.
  • Mark Suszko
    September 11, 2009 at 2:34 pm
    Chris, my brother, I give you a hearty A-MEN. I feel your pain.
    It all comes down to money. It always does. Stations don’t want to spend any, until the spending guarantees a huge return. So we’re stuck with a lot of SD being uprezzed at the transmitter to technically become HD, and stations hanging on to SD infrastructure as long as it can be somehow made to produce… since it is already paid for.
    The other problem I see that drives this painful situation is that there are no more “common” standards, too many different formats and flavors means nobody can afford all the decks and associated gear to handle stuff in the traditional mechanical manner. What I feel is happening is that for cost reasons, everything is going the direction of FTP for distribution and delivery and we will see fully IT-based plants, where you will never see a deck or tape of any sort, and very few disks either. It will happen because it is cheaper and more efficient to do it that way. There are already services like DG Fastchannel for doing this kind of thing, the next big growth spurt will be a burgeoning of these services and some kind of coalescing into an eventual ‘standard’ dictated by market pressures and not SMPTE.
    Meanwhile, back in the edit suite, we’re facing a recurring problem that happens whenever technologies make a jump. When the new technology is first brought in, it is not fully utilized in the “best” way, but people try to fit the old paradigm into the new media framework. Easiest example of this would be when motion pictures were invented, they just placed a single fixed-lens camera in the third row of a theater and did the play in front of it. Only later did the moveaeble camera and editing make a real change in how the plays were recorded and how the story was told… and cinema became a unique artform.
    We are now jamming SD material into widescreen frames and having to shoot and edit to ‘protect’ the center frame as a nod to backwards compatibility. This makes for horrible compromises in aesthetics that make the product equally bad for either frame size. Nobody is able to say with certainty when we’ll be allowed to stop “needing” to do that, and that means a danger of it becoming a “habit” for people who are not constantly re-evaluating what they do and why.
    When will we be free of that? To some extent I think it depends on when people using 3:4 screens drop below a certain threshold number in market surveys. We are shooting and editing in HD and then throwing away much of the expense and effort as we bump it down to SD for final delivery. This won’t be forever, but nobody can say for sure just how long this transitional period may last. If you want to start a pool, put me down for 12 more years of this “half-life”. Might take that long for the rest of the old SD gear in the stations to finally die beyond hope of economical repair, and THAT is what will force them to finally upgrade.
    I know a bunch of guys here will say its always worth it to shoot everything in HD now. They give various reasons like future-proofing it against the time when everything is truly HD end-to-end. Well, I only partially agree. Again, it comes down to a cost/benefit issue, in that some material we produce is never going to need to last long enough to outwait the full end to end progression to HD everywhere. And some of it is for an audience that is perfectly happy with 3:4 they’ve grown up with. Some things we shoot as lot of, like a stand-up lecturer with slides, don’t really gain anything from the extra screen realestate unless you design from the beginning with that in mind. More to the point, maybe, their own in-house viewing infrastructure is likewise bound by old gear and unlikely to convert unless under the duress of replacing dead gear that’s just not made anymore.
    So we wait it out. And grit our teeth in the meanwhile.
  • Todd Terry
    September 11, 2009 at 2:35 pm
    Two of our three suites are HD, but to date we have produced exactly one HD project for broadcast… a 30-minute program for Public Television. All the rest of our HD productions have been for things like trade show displays, etc.
    We have never produced a commercial that ended up airing in HD, as none of the stations that we serve can take them yet. All of the stations say they are HD, but really meaning that they just pass on the networks’ HD signals, nothing originating from them is in HD, it’s all still the SD Betacam world.
    Sometimes we will produce a commercial in HD, if it’s something we think is going to be around for a while, or something good enough to put on our reel. In those cases though the broadcast delivery is still an SD version. We will either do a center-punched or letterboxed version for SD… it’s exactly the same amount of extra work with either version.
    Strangely enough, about a year ago we did get a call from one of the advertising agencies that we serve saying that one of the stations that we regularly send commercials to (in another state) can now accept HD commercials. Which was very surprising, considering that particular station is in a very small market. The big market stations we serve still want Betacam only.
    Not sure when that will change… although I will be glad when it does.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Todd Terry
    September 11, 2009 at 2:39 pm
    Just an addendum… and a pet peeve….
    How many times have you been to a public place (doctor’s office, restaurant, bar) where there is a 16:9 set displaying a 4:3 picture all stretched out? I see that all the time and it drives me nuts.
    Just last weekend we went to a sports bar/restaurant that had about 10 different monitors around the room all showing different things. Eight of them had the aspect ratio wrong. Grrrr.
    Full conversion can’t come too soon for me.
    T2
    Todd Terry
    Creative Director
  • Mark Suszko
    September 11, 2009 at 2:44 pm
    Todd, I bet the reason the small station converted and the big wone hasn’t is that the small one had amuch smaller investment in still-operable gear. I would guess they jumped direct from creaky s-vhs and some betacam tape playback into HD gear, without intervening technology steps.
    You see something like this in third-world countries where they leap directly to cell phones and don’t bother trying to lay conventioanl long distance phone cables anymore.
  • Tim Wilson
    September 11, 2009 at 3:20 pm
    [Todd Terry] “How many times have you been to a public place (doctor’s office, restaurant, bar) where there is a 16:9 set displaying a 4:3 picture all stretched out? I see that all the time and it drives me nuts.”
    As the AV nerd for both sides of the family, as far as the term can possibly be extended, I set up a lot of TVs. Without exception, every time I set up them up to protect 4:3 pictures, people FREAK OUT.
    Here’s the thing – nearly all of them get that it’s stretched SD. They don’t for a minute think that it’s really HD, and would rather the picture be distorted than not. I think there’s a combination of “I bought all these pixels and don’t want to waste any of ’em” and the discovery that things are more fun to watch on wide screens.
    (I think there are physio-anthropological reasons for this, but that’s another story. I’m also aware that many people outside my sphere influence have no idea that they’re not getting HD.)
    Here’s the thing I’m a little embarrassed about: I’ve gotten kind of fond of stretching 4:3. I watch so little of it that I don’t feel particularly strongly about the sanctity of the frames.
    And seriously, anything playing on a TV in a public place deserves to be disrespected. If stretching is the most that can be done without actually tearing the thing from the wall, well, then so be it.
  • Todd Terry
    September 11, 2009 at 3:52 pm
    I think “organizing” or at least planning ahead for HD (at least on the network/national level) seems to be getting a little better.
    About a year ago, the majority of commercials airing on networks during HD programming were still SD spots. Now, the vast majority of them are HD. It’s kinda fun to toggle back and forth between a station’s SD and HD signals to see how each particular advertiser handled the difference. With some, the 16:9 HD version is centerpunched for the SD version. With some, the SD version is letterboxed. I’ve even seen some HD spots that were pillerboxed so you still saw only a 4:3 image, but in HD. In those cases the HD and SD versions looked identical both cropping and ratio-wise… the only difference was the line count.
    It’s the same for network programming… sometimes an HD show is letterboxed for the SD version. Other times the SD version is a centerpunch.
    What’s funny is to see a SD commercial airing on an HD channel, but where the original SD production was letterboxed. In those cases, when it appears on HD it is both letterboxed and pillarboxed… so you get the spot small in the center of the screen with black around all sides. You used to see this a lot… now, not so much. I think people are finally catching on.
    T2
    Todd Terry
    Creative Director
  • David Roth weiss
    September 11, 2009 at 5:14 pm
    [Tim Wilson] “Here’s the thing I’m a little embarrassed about: I’ve gotten kind of fond of stretching 4:3. I watch so little of it that I don’t feel particularly strongly about the sanctity of the frames. “
    Tim,
    A friend of mine has a new Samsung that operates at 240hz. I’m not quite sure why, but SD scaled or stretched on that TV is better than HD on most other TVs.
    HD, especially movies, look so good that I don’t like it. It’s actually too crisp, kind of like we all found out years ago when there was a brief trend toward shooting film at 30fps for telecine. Remember, how it looked like video, not film???
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
