Activity › Forums › Apple Final Cut Pro Legacy › when ftg is same – when not to Chg seq settings to match clip settings?
  • when ftg is same – when not to Chg seq settings to match clip settings?
    Posted by Paul Dougherty on December 2, 2011 at 9:21 pm
    If I am making a sequence where 90% of the camera footage is the same, when would it be wrong to “Change sequence settings to match clip settings?” To match the dominant source material?
    Paul
    Chris Tompkins replied 14 years, 10 months ago 2 Members · 1 Reply
  • Chris Tompkins
    December 3, 2011 at 5:25 pm
    Since you’ll probably be fighting a render with the un-matched footage, you should go with what the most footage is.
    Chris Tompkins
    Video Atlanta LLC
