Activity Forums Apple Final Cut Pro When FCPX Render Fails
  • When FCPX Render Fails
    Posted by Ken Bennett on May 31, 2017 at 10:38 pm
    What are my options to get a Project rendered out to an MP4 when I get this error message:
    The share operation “Master File” has failed.
    Video rendering error: -50 (Final Cut Pro error -50: renderVideoFrame failed)
    Advice??????????
    I also get the the following message when I start the Share to MP4, and nothing is showing in the Background Tasks window.
    “” has background tasks that are not yet complete.
    If you continue, these effects may be missing or have reduced quality: Stabilization
    Advice ????
    Help!!
    THX
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Mark Suszko replied 9 years, 3 months ago 5 Members · 5 Replies
  • Jeff Kirkland
    May 31, 2017 at 11:42 pm
    My first thought would be to delete all the render files and try again.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Noah Kadner
    June 1, 2017 at 12:02 am
    Can occur when there’s a bad piece of source media- but yeah blowing away renders will probably clear this out.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Ken Bennett
    June 1, 2017 at 2:14 am
    I did delete all rendered files, toggled the codec, let it rebuild the needed rendered files and my Shared MP4 was processed completely.
    Thanks.
    Ken Bennett
    Video Adventures
  • Jeremy Garchow
    June 2, 2017 at 2:45 am
    [Ken Bennett] “let it rebuild the needed rendered files”
    For next time, there’s no reason to render first, you can share without rendering.
  • Mark Suszko
    June 2, 2017 at 4:25 am
    I have not always found that to be the case, Jeremy. As you can see in my question above.
