Activity Forums Maxon Cinema 4D When extruding doesn’t recognise center holes of letters
  • When extruding doesn’t recognise center holes of letters
    Posted by Sophie Hollies on May 14, 2018 at 11:25 am
    Hello I’m a bit of a newby to cinema 4D but i’m having a very frustrating issue with importing text from ilustrator into the software and I can’t seem to find any information anywhere about this issue online. When I import text and extrude it, it doesn’t recognise that my letters A, D, O etc have a space that should be cut out. I’ve tried ‘Connecting & delete’ the path but I only have 1 path per letter (not enough paths to connect, the option ‘connect & delete’ is greyed out). I made sure that all my paths in illustrator were outlines and I saved my illustrator document as an illustrator 8 file and merged into cinema 4D. WHat am I doing wrong? :/ I would appreciate any help. Thanks :))
    Matthew Oneill replied 8 years, 3 months ago 3 Members · 2 Replies
  • Brian Jones
    May 14, 2018 at 4:29 pm
    the problem is likely with the Illustrator file itself since you have the parts for each letter all in one spline, can you post the Illustrator file (the Illustrator 8 version) or the C4D scene file?
  • Matthew Oneill
    May 16, 2018 at 11:33 am
    Most likely the centre hole of the letter D has a double skin of splines.
    Disable the extrude
    Enter point mode
    Select the spline for the letter D
    click one spline point along the centre hole
    Use Select > Select Connected
    Now try moving the points around, likely youll see there is still a ghost left behind because you had 2 holes in the same place. Delete one of them.
    Mash
